[SOLVED] What is the problem with my gpu?
Jan 15, 2020
4
Pc turns on but there is no dysplay output comming from the gpu the fan spis and my psu is a termaltake oem psu and it is pretty old.
i Bought it the other thay and we don't know if it was working and it was changed fron an hd 5450 dell oem 1Gb
If you don't know if it was working, you need to strip it down and start from scratch--cpu and ram and see if it boots. If okay, add gpu, check if it boots. If okay, add boot drive, see if boots, if okay, keep adding other stuff back until you have everything connected.
