[SOLVED] Would EVGA and Palit same model graphics card be able to connect via SLI?
Sep 1, 2019
7
Hello,
I have one old Palit nVidia geforce 9800 gt graphics card and want to buy another one to connect them in SLI. I found one online but it is EVGA one but the same model.
Would this be a problem or should I look for another Palit one?
Additional:
Motherboard: ASUS M2N-Sli deluxe
CPU: AMD Athlon 64 x2 4800+
Thanks!
If they are the exact same model, brand doesn't matter. You'd be better served spending your money on a single good gpu though, the performance gain for cost just isn't worth it.
Can you recommend one that is better than two geforce 9800gt and that will be compatible with ASUS m2n-sli deluxe?
