[SOLVED] B450 Aorus Elite Fan Header Voltage Limits
Sinxph
128
I didn’t realize how little fans I could attach to my motherboard. So, I just bought a fan splitter from rosewill but I need to know how many fans I could attach to one header. On the front of the fans it says DC12V 0.16A.
Can I attach two fans to one fan header on this motherboard without any issues long term?
They are called the Rosewill 120mm case fan 4-pack Long life sleeve bearing computer case fan ROCF-13001 Ultra Quiet Computer case fan
I just downloaded the manual for your motherboard and it doesn't explicitly state the current limit of the fan headers.
But 1 Amp is the industry standard for a fan header.
So I feel fully confident in telling you that you can connect 2 of those .16 Amp fans to each header safely.
If you need further assurance of that you should contact Gigabyte support and ask them to confirm that.
But just as a reference, I personally have 2
.25 Amp 2000 rpm 120 mm Rosewill fans per header on my Asus ROG Strix B450-F Gaming motherboard and I would not hesitate to run 3 per header if I needed more fans.
As long as you don't exceed .9 Amps per header you should be fine.
Check your motherboard specifications, each fan header should be rated for 1A.
So the general rule of thumb is that you can connect three fans (usually .25A each) per header safely.
So if they are .16 Amps each you can safely connect 2 or 3 per header as long as your motherboard supports 1 Amp per header.
So the general rule of thumb is that you can connect three fans (usually. 25A each) per header safely.
I can’t find anything regarding fan headers and their rating in the motherboard specifications. Could you help me out please? It would help a lot.
Perfect. Thank you!
