if you're using the latest driver package available it wouldn't continue to cause the same issues after being totally removed and reinstalled.
it's more than likely the GPU itself failing.
you can also try reinstalling the OS with a drive wipe and fresh install package.
many times a corrupt OS can also lead to issues like these.
If you are looking for the Windows 11 Clean install tutorial, you can find that here: Windows 11 Clean install tutorial (Click here) Otherwise, welcome to the Windows 10 Clean install tutorial This tutorial is intended to help you, step by step, to perform a clean install of Windows...
forums.tomshardware.com
find a friend, family member, coworker that will let you test with theirs.
