Need some advice for case air flow. I have 3 fans on my AIO top mounter pulling air into the case (Case>Rad>Fans). 1 intake fan in the back. My Rad tubes are not log enough to front mount with the tubes coming from the bottom of the Rad (tubes on bottom are recommended for air bubble issues). 3 exhaust fans in the front. Overall the CFM is about 20 higher intake than exhaust. GPU temps are good under load it seems, in the 60s max 70c. But my 5900x is getting up to 80c when playing PUBG. I was thinking about flipping all my fans around but idk if it will help and then the exhaust will be 20 CFM higher. Please help and thank you.
Case: Phanteks P600S
Read Intake Fan: 1 Arctic P12 PWM
Front Exhaust Fans: 3 Phanteks PH-F140MP
CPU: 5900X
AIO: EVGA CLC 360 (Replaced fans with Arctic P12 PWM)
GPU: 6800XT
CPU: 5900X
GPU: 6800XT
