Hello guys,
Not sure if this is a common question, i did google it and to my surprise i found literally nothing. Maybe im a bad googler.
Anyway, on initial startup sometimes, my cooler tends to make a weird noise. It sounds like a pump trying really hard to pump the liquid but its super loud then gradually gets smoother and smoother and then its absolutely fine and very quiet.
This only occurs for the first 2 mins or so when i turn my rig on and even then it isnt everytime.
This is my first AIO so im not sure if this is normal and i genuinely couldnt find much on google about noise on startup.
Any help would be appreciated as always
Thank you,
Ryan
Thank you,
Ryan
