[SOLVED] CPU 90°C not in full load
Hot___
81
Firstly, I had an i5 2400, in load it had 80°c with thermal paste almost all dried up.
Now I have an i7 3770 , same cpu cooler and i get 90°c ( not 100% load) while playing cs go. I changed the thermal paste a few hours ago again( before it had 100°c+. Now it does not pass the 100° but still 90°c...
Might it be from the thermal paste not good enough or I applied to much or is the cpu cooler not making good contact with the cpu. I tried with another intel stock fan( the metal part was a bit smaller) and the same results.
The case is open, i haven't installed the left panel.
Also the thermal throttling is activated in BIOS but I see no change in fps.
Obviously - you need a better cooler.
Intel stock coolers have never been any good. For simple web browsing they're fine. But for gaming workloads a better cooler is necessary.
Deepcool Gammaxx 400 - for example.
Ok. But how does the mounting work? They are all standard or i need to search for one that has that plastic things like the intel ones. My mobo has 8 holes for the cooler. I don't know if theywork with screws.
Edit: I've found a gammaxx 300 or a 200t, are they good enough?
Mounting will require a backplate to be installed, so you have to remove the motherboard and attach it. Then the cooler screws into the the backplate to achieve the correct amount of force.
Latest posts
