Question Cpu Temps is not "stable" with a low fps
Jun 25, 2021
16
Guys i build a pc before 3 months with i7 10700 Cpu And Asus Strix B460-h the cooler is corsair H100i V2 and everything was okay before 2 days my SSD failed and i replaced it with new Evo Plus 970 from Samsung i dont know if this mean anything to my problem !
I reinstalled the windows with the latest updates and the pc work fine except when i open any window like lts say edge browser or any file or steam launcher or lts say i want to start a video on youtube the cpu Fans Start Rolling fast and noisy and the cpu Temp go to 70+ for some seconds until the load is done and still high.
by the way idle temps while in bios is 32 but in windows reaches 40 i know it not that high but room temp is much lower and tepms is not stable it jumps for some seconds each time i load something and the fps in light games is not normal even on 720p resolution i was playing on that cpu for 2 months and it was okay with a lot better fps before that problem
I tried default bios settings
I checked the pump it says 3000 rpm on corsair link and the fans is optimized well
and got No Gpu yet !
Did you remove the thermal cover from the cooler? Is there thermal compound? Did you make sure the cooler is properly seated
The cooler is working well from almost 2 months or more and i didnt changed anything in the hardware except adding nvme 970 evo plus and some cable managments i think its a software problem maybe windows or driver or bios ?
