[SOLVED] For rendering and i9 10900F or K?
pacmaniack
22
Hi, so i have this question, will it be bad if i buy i9 10900F instead of K?
i want to economize, for 3D rendering, video editing, professional drawing and all related to design, im abou to change from i5 9600k to a 10th gen I9 but i don't know if it is a huge difference between i9F or I9K? i have budget for both, but if i don't really need to overclock or need integrated video graphics, i play last gen games but don't complicate my life about high end quality graphics..... Will it worth to get the i9 F version instead of K? what you guys suggest me? or should i get the normal i9 10900?
Does that frecuency difference affects a lot when video editing or rendering?
i 9 10900f (2,80) vs i9 10900k (3,7)
I don't usually do overclock
My actual PC specs
i5 9600k
Gtx 1070 8gb
16gb Ram
The 10900F has a 65W TDP rating.
https://ark.intel.com/content/www/u...0900f-processor-20m-cache-up-to-5-20-ghz.html
At default settings, the 10900F will throttle like crazy when fully loaded. If your time is important to you, spend the extra money and get the 10900K or a 10850K would be a good budget choice. Any time you do some 3D rendering, you will be glad you spent the extra money. Get a good cooler too.
Reactions: pacmaniack
