Having serious performance issues with my frames in games recently despite low gpu/cpu usage and temps. (RTX 2070, Ryzen 2600x)
I've noticed in games like FiveM and Rust, for example, my friends with a 1060 and 1080 both run higher frames than me, with a 2070, even when I'm running all low settings and they're on ultra. I looked into it a bit and can't figure out any solutions for my specific problem.
Some basic information: (also things that could be relevant)
- In Minecraft for example I run 12 chunks and maybe get 70-80 fps in all vanilla
-My boot drive has little space left
- I use my 2nd monitor for gaming, and it is marked as the 2nd monitor in windows. My primary monitor is not the main one I use so-to-speak. I do this because it takes the activated windows watermark to my other screen. I don't mind changing it back. (This could be it but I'm not sure.)
I'm guessing it is maybe some option I have enabled that is capping my gpu and cpu performance but I can't figure out why or what it is.
I'm Willing to run any benchmarks and follow any instructions to the teeth if need be. Any help is much appreciated.
Specs list:
- Ryzen 5 2600x
-32 GB of 3200mhz RAM running in dual-channel ( I cannot tell if I have enabled XMP or not in my bios. It only lists one stick as running 3200 MHZ and I'm just not 100% sure it is enabled correctly.)
AOC 24V2W1G5 75hz Monitor (Secondary but marked primary in windows)
(can expand if needed)
https://www.userbenchmark.com/UserRun/45320807
- I have the latest Nvidia drivers as well as the latest Windows update
- I have set both Nvidia and windows power plans to max performance
Specs list:
- Ryzen 5 2600x
- 1 Tb WD Blue HDD
- 500 GB m.2 ssd (Boot)
- B450 Aorus Elite
- Asus ROG Strix 2070
- EVGA 550 B3 psu
- Coolermaster AIO
