Question How do I use RTX 260 without a DP port
PCN00B123
132
5
18,685
I've bought an RTX 2060 but my BenQ ZOWIE XL2411 144hz monitor doesn't have a DP port. What can I do? I do not have a lot of money left to spend.
You will not be able to get 144hz unless you have a dvi on the graphics card itself, even if you use a connector it will still be 60hz, unless you spend 100$. My advice would to be live with 60hz or try to return the rtx 2060 you got and get the closest graphics card with a dvi instead of spending 100$ on a connector use it to upgrade to something with a dvi
