[SOLVED] I Need help pls
Oct 20, 2020
6
Hi everyone.
Sorry if i make some errors writing but english is not my mother tongue.
i bought a lenovo legion t530-28icb used on the internet with only the motherboard , i5 8400 and a stick of ram 8gb 2666 ramaxel.
bought a new psu Antec 600w and a new fan for the cpu And the computer was completed.
when i power it on i hear 2 beeps and nothing..... no boot.
bought new ram crucial 8gb 2666 tried it in every slot still 2 beeps and no boot. So the ram is not the problem.
tried to reset the CMOS battery. It starts after that for 4 secs, restarts and still 2 short beeps and stays on but no boot.
is there a motherboard problem or should i go with lower speed ram???
The motherboard is a b360 with no support for xmp profile, i’m not a true gamer. I just want to make it work and maybe play dota 2 sometimes. Bought it for 100€+ 70€ for cpu fan and psu antec, i hope it was not for nothing.
thank you 🙏
Thanks alot for the reply. I have only the arctic mx12. Tried even with the fan disconnected. Still 2 beeps. I’m afraid is the mobo. I have a mars gaming(cheap) psu. I will try today with that one and i will tell you.
Does anything comes on your screen?? I found that 2 beeps on Lenovo Mobo usually means POST error and displays some error on screen.
Hi everyone.
thank you 🙏
Did you try again with your old cpu fan and psu if not try them individually go with cpu fan first. And if your ram dual channel or single?
