Sep 1, 2019
So at the moment I have got a
Ryzen 3 2200g
A320M S2H CF MOBO (Which can only be used with 1st and 2nd gen Ryzen processers and ram wich is 2666mhz ram and up to 16gb)
RX 570 (4 GB )
8GB of 2400mhz ram
1tb black hdd
Cooler master matsterwatt lite 400 psu
I am looking for some help on what to upgrade and what order to do it in. I am looking to play games such as destiny 2,R6,Rust,Ow,GTA5 at a good quality with high fps be good if anyone can help me out cheers.
Monitor resolution? Budget?
Your psu is a very bad pairing with a 570. I would swap that out for a quality 450 or 550w asap.
Also, i would get 2x8gb ddr4 3200mhz.
The a320 choice is also a bad idea.
At the moment im not really sure on what I am going to spend but I am trying to get things that aren't extremely expensive, I have a Samsung monitor, 24" curved I don't know much about monitors but there is the link to it if it helps https://www.currys.co.uk/gbuk/compu...up&gclid=COTntf6LsOQCFVVOGwodt7YNHg&gclsrc=ds
