Make and model of the fans you want to use? If your fans are either PWM or 3 pin(voltage regulated) then your PWM fan hub will work, just that it needs to be plugged into the CPU_FAN header, have the rest of the case fans connected to the hub as well.
Quite a mess here. One of them is https://noctua.at/en/nf-p14s-redux-900
I also have one of these https://www.corsair.com/uk/en/Categ...IES-LED-CONFIG/p/CO-9050017-RLED#tab-overview
For the other 2, im not too sure what to buy. Im assuming they both have to be 3 pin? thats all that matters? (and that they have to fit my case but that isnt an issue)
