[SOLVED] Low CPU and GPU usage
Mar 13, 2020
I have a RTX 2080 and an AMD Ryzen 2700X. I have a problem with getting low FPS.
In task manager it shows that the CPU usage is at 30-40% and the GPU usage is at 10-15% while gaming. Is this normal or is it too low?
What game?
What FPS?
What resolution?
What game settings?
Total cpu usage is fairly meaningless, you need to monitor each core/thread. If only takes 1 at 100% to limit performance while total cpu usage is much lower.
What game?
What FPS?
What resolution?
What game settings?
i have the same problem and all cores roughly have the same usage,my cpu is always at 40% usage and my gpu at 20% when i play fortnite and my fps drops from 144 to 20 alot of the time
my specs-r7 2700x @ 3.7ghz
nvidia evga gtx 1660
16gb ram @3200mhz
