hi i need help, my motherboard has only 1 (3 pin) fan header, not including the cpu header, the motherboard is a Intel P55 Wide Use LGA1156 DDR3 motherboard, i am trying to hook that header with 3 X 120mm fan which is ALSEYE 120mm FAN white 12v 3Pin Air Cooler Cooling fan, i also have a Chasis Cooling Fan Power Cable Hub Splitter Adapter would i just put the these three fans to this hub splitter and everything work okay would it damage the single header? thanks
motherboard: https://www.ebay.com.au/itm/Intel-P...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
fans: https://www.aliexpress.com/item/32815903311.html?spm=a2g0s.9042311.0.0.698a4c4dPU4h5T
hub splitter adapter: https://www.aliexpress.com/item/32840829421.html?spm=a2g0s.9042311.0.0.7f374c4dfM8M3w
