Question Msi A520M Pro VH or Asrock A520M Hdv for ryzen 5 4650g . Which is better ?
Aug 5, 2022
17
I want to know which is better ?
Asrock motherboard support m.2 to work with cpu or it's only a normal m.2 without cpu control ?
I heard Msi A520M Pro motherboard m.2 not get proper speed because this m.2 is not connected with cpu. What is the way to know if a motherboard m.2 can gain more speed from cpu or not ?
Even without "full speed", you will never notice the difference in real world usage. There is a big performance jump going from spinning disk to SSD. But the gains are very minor after that. SSD -> NVMe or PCIe 3.0 to 4.0 or 5.0. The biggest improvement is moving off spinning disk.
Reactions: Lutfij
One youtuber said, gigabyte a520m s2h motherboard m.2 work with cpu but msi a520m pro can't. How he know that ? How i can notice this ?
Honestly? I wouldn't get either of them...that's because it's me. I also don't know what your system will be used for. To also add, I don't know the rest of your system's build. Might want to include them to add context.
I will use ryzen 5 4650g
Pny 8gb 3200mhz
Any nvme but i need a m.2 slot which work with cpu
^ One pcle 4.0 nvme
1 x Ultra M.2 Socket, supports M Key type 2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s
^ https://www.asrock.com/mb/AMD/A520M-HDV/#Specification
  • 1x M.2 slot (Key M) (from AMD Processor)
    • Supports PCIe 3.0
    • Supports SATA 6Gb/s
    • Supports 2242/ 2260/ 2280 storage devices
^ https://www.msi.com/Motherboard/A520M-PRO-VH/Specification
https://storage-asset.msi.com/datasheet/mb/global/A520M-PRO-VH.pdf
if this is your first build, don't waste your effort getting a PCIe 4.0 SSD. Both motherboard slots will operate at PCIe 3.0 speeds. I don't see any need to go PCIe 4.0 for a platform that won't go beyond PCIe 3.0
What will you use this system for? Mentioning your usage scenario and app's will help us two fold.
Link to the video, please. I never said you've invested in your build, now did I?
Please stick to one thread, unless you want spaghetti brains.
View: https://youtu.be/974-GeXnTFw
Thanks a lot for your help. I will go for asrock only for faster nvme support & I also heard for gpu, asrock uses a better stronger pcle slot, so in future I can use dgpu . I am totally confused about msi m.2 nvme support & their build quality is not good although bios design is wonderful
