Nov 10, 2019
So like, I have a budget of 2000 aud for everything in the PC and a monitor, chair?(not essential), case, and also, i have to use wifi not ethernet so a motherboard that uses wifi would be good. im hoping to be able to run AAA titles easily with at least 60fps on 1440p. with that said I have this build so for with the help of people from another post and my friends irl.
PCPartPicker Part List: https://au.pcpartpicker.com/list/zNRyk6
CPU: AMD Ryzen 5 3600X 3.8 GHz 6-Core Processor ($375.00 @ Mwave Australia)
Motherboard: Gigabyte B450 I AORUS PRO WIFI Mini ITX AM4 Motherboard ($194.00 @ Shopping Express)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 Memory ($125.40 @ Newegg Australia)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive ($156.00 @ Shopping Express)
Video Card: Gigabyte GeForce RTX 2060 6 GB GAMING OC PRO Video Card ($599.00 @ BudgetPC)
Case: Phanteks P300 ATX Mid Tower Case ($89.00 @ PCCaseGear)
Power Supply: SeaSonic FOCUS Plus Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($149.00 @ Mwave Australia)
Operating System: Microsoft Windows 10 Pro Full - USB 32/64-bit
Monitor: Asus VG278Q 27.0" 1920x1080 144 Hz Monitor ($339.00 @ Shopping Express)
Total: $2026.40
Generated by PCPartPicker 2019-11-13 15:42 AEDT+1100
Thanks in advance!
Just my thoughts:
  • Agreed that 3200 is just as suitable, you likely won't notice much difference between 3200 and 3600 RAM.
  • Crucial P1 is fine, the only alternative I would consider and usually recommend is the Intel 660p. Ultimately, you likely won't notice a difference from any NVMe over any standard SATA SSD.
  • Just looking at the price difference of 60AUD - 3600 will be just as fine as the 3600X. Most people opt for the former as the 3600X is only the tiniest of improvements - effectively it's just better binned chips. But obviously that's just food for thought.
  • Also remember the B450 will need to have a newer BIOS prior to installing a 3rd Gen ryzen to work.
  • Excellent choice in PSU by the way!
-i would go with 3200mhz ram and get samsung nvMe.
-you also didnt mention a cooler, so i am assuming you sticking with stock cooler, which is good for stock speed.
also i think b450 dont support 3rd gen ryzen out of box, they need Bios update, i could be wrong on that.
rest of the build seems solid
Yeah you're right it doesn't, is it hard to update the bios with this board?
Or should I go with the x570-A PRO
Just my thoughts:
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($314.00 @ Shopping Express)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory ($101.20 @ Newegg Australia)
Monitor: Asus VG278Q 27.0" 1920x1080 144 Hz Monitor ($368.00 @ Shopping Express)
Total: $1970.20
Generated by PCPartPicker 2019-11-14 10:17 AEDT+1100
Just my thoughts:
Total: $1970.20
Wow thanks for that, abit of a late reply, I was just wondering if a bios update is hard to perform. Cus I dont wanna mess the computer up straight after i get the parts.
For the BIOS update, unless your board has BIOS flashback, you can only update the BIOS with an out of the box compatible CPU installed (for B450, you'd need a 2nd gen ryzen to do so)
The parts will fit on the ITX board you linked, but you'll need to verify if the parts fit in an ITX case (usually CPU cooler and GPU clearance)
However you have a mid tower linked, so no problem. Remember for an ITX case you'd likely also need a SFF PSU.
Any reason why an ITX board in a mid ATX case?
