So my PC only boots sometimes (that's an understatement) but when it does it runs perfectly fine.
Most of the time it has no video output and no usb function and hangs, with no indication it's running apart from fans and LEDS, it turns off instantly from this state upon pressing power button.
I have tried probably every troubleshooting option, that i've seen from any similar issues i've found on forums.
One of note is that I did buy another PSU already, however, it is the same model that I already had. It didn't change anything.
I bought the same PSU because my PC ran with all the exact same components fine for a long time before this issue started happening, it was a much cheaper, and of course I don't know if PSU is even the problem so didn't want to spend much on it
I've seen other's seemingly having the same issue where a better & higher-wattage PSU has fixed the problem, but also lot that a new PSU didn't fix.
Was buying the same wattage, same model PSU a mistake?
PC Specs
Mobo: MSI Z790-S WiFi
CPU: i5-14700Kf
GPU: Asus TUF 3080 Gaming OC
RAM: 16GB DDR5
SSD: 1TB NVMe
PSU: Corsair CX750
PC Specs
CPU: i5-14700Kf
RAM: 16GB DDR5
SSD: 1TB NVMe
PSU: Corsair CX750
