Hello, everyone!
I've been experiencing a peculiar and frustrating issue with my office PC lately and I'm at my wits' end trying to resolve it.
PC config:
AMD 3600xt (stock fan)
Gigabyte B550 GAMING X V2 (rev. 1.0) motherboard
Corsair Vengeance LPX 16GB (1x16GB) DDR4 3200MHZ x3 [48GB in total)
ZOTAC GAMING GeForce RTX 3080 Trinity
WD Blue™ SN570 NVMe™ 500GB SSD
DQ750M-V2L fully modular 750W 80 PLUS Gold power supply (220 V input)
(PC routed through Luminous PowerX 2250 Pure Sinewave UPS Inverter)
1TB 2.5" HDD x1
500GB 3.5" HDD x1
Two monitors connected using DP and HDMI
This PC is being used for rendering and office work.
Symptoms:
1. Erratic/unpredictable power-on behavior: I leave my office at 6pm, shutdown/hibernate the PC and switch off the PC from the wall socket before leaving. I turn on the wall socket the next day at 10, it won't start immediately as I push the cabinet button. I've found that it turns on if I leave the wall socket on for about 15-20 minutes. Once the wall socket is on for the stated duration, pressing the power button usually turns on the computer. At times, to avoid inconvenience in the next morning, I shutdown/hibernate this PC but leave the wall socket on. There is no problem the next morning when I push the power button. It powers on immediately.
2. Time change in BIOS: once it starts after 15-20 minutes, the time is never synced.
3. RGB on USB keyboard stays on even while PC refuses to power on.
What all I've tried:
1. Swapping CMOS battery: I swapped the CMOS battery with another PC's. To no avail! The other PC with my PC's CMOS battery works just fine without any date and time issues. I've tried turning on my PC without CMOS battery as well, to no avail.
2. Resetting BIOS: Resetting BIOS through BIOS reset jumper (and CMOS battery too) but to no avail.
3. Updating BIOS: My bios was version 1 from 2020 august. Just updated it to the latest 17th version. It behaved well for one day, same issue thereafter.
4. Shorting PSU: I tried shorting PSU through motherboard power connector (while it is still plugged into the motherboard) using a metal pin. It powers on like a zombie. All fans and RBGs turn on but no display, and no usual fan speed drop (as is after normal boot up). As soon as I remove the pin, the PC and PSU drop dead. Problem persists thereafter.
5. Swapping PSU: Tried swapping Deepcool PSU with a 650W Thermaltake PSU (80+) but to no avail. Thermaltake PSU works just fine in the other PC. I've not yet tried using the Deepcool PSU in another PC.
6. RAM swap/realignment: I've tried all permutations and combinations to plug the RAM sticks to my motherboard. Nothing helps.
7. Cabinet Power switch: I've checked PC cabinet power switch using continuity feature on my multimeter. It works just fine, everytime!
Final comments:
I'm so frustrated due to this problem. I have no clue what has gone wrong. Please help with this issue. Has my motherboard gone bad? Is it my PSU, or something else?
Please help! I can try troubleshooting as you friends instruct.
Thank you so much, everyone! Really appreciate it.
Cheers to Tom's Hardware
PC config:
1TB 2.5" HDD x1
500GB 3.5" HDD x1
Symptoms:
Final comments:
