So 2 Months ago i was sitting at home and my gaming pc was in sleep mode , suddenly i heard explosion coming from my pc , exactly from my psu 400w without any sticker that show which brand is , i replace the psu with cx 450 and install it in the motherboard , connect all the pins correctly and test it fortunately it turned on without any problems , i bought cooler master cooler evo 212 with it so , i unplugged everything again and put thermal paste over the cpu and installed all of the screws and then when i turned my pc on , all of my fans ( including cpu , gpu , and psu ) were spinning with no signal on the monitor , i googled it and read all the forums so i changed the ram slots , and turned it on again then it worked so fine , when i tried to restart the pc , i had the same problem again , i tried to switch the ram slots but no results , so i decided to unplug the hdd pins and plug it again in the motherboard then it worked again , i decided to play games on it because even the cpu temperature was below 35c , i was playing for 5 hours without any problem , then i turned the pc off to go sleep , and then on the morning i pushed the on button and had the same problem , so i tried to unplug the hdd and plug it again it didnt work , i tried to change the ram slots and it didnt work either , reinstalled the cpu and even the cpu cooler without anyresult , the ( psu , cpu , gpu) fan keep spinning and no signal on the monitor , so i tried to reset the bios setting through taking off the battery , unplugged the power grid , waited for 30 mins and then plugged everything on again and then when i pushed the on button , the cpu fan and psu and the gpu fan were spinning for 3 seconds and stopped and the pc keep restarting again , with no light on the button , except the hdd led was flashing , i tried to reset the bios through the jumper with no results , the psu and cpu and the gpu fan were spinning for 3 seconds and stopped , and the pc restart , i dont doubt because of the psu because i just bought it , i doubt on the motherboard could be dying or something i even tried unplug and plug the front header with no result , i doubted there was short circuit between the metal and the case so i unplugged everything and took the motherboard and put it on the card board with no result , all of the fans keep spinning and stop for 3 seconds , i bought the new 3v battery and plugged in and again no results , could someone give me the reason or help me to figure out what is wrong , THANKS
PC SPECS :
CPU : I5 3570k
GPU : GTX 960 2G
RAM : 1x2 gb , 1x4 gb
HDD : 250gb hdd
PSU : CX 450W
MOTHERBOARD : MSI B75MA-P45
CPU COOLER : COOLER MASTER EVO 212
PC SPECS :
CPU : I5 3570k
GPU : GTX 960 2G
HDD : 250gb hdd
PSU : CX 450W
