[Moderator edit to break up one continuous paragraph of text.]
I've read somewhere on the internet that even if someone manages to repair a CPU's pin, that it will never ever match the feel and performance of a CPU's pin that has never been touched or damaged.
And I believe this could be true in some scenarios, if I'm not mistaken, CPUs are manufactured and assembled by robotic mechanisms in the factory. So producing and assembling a CPU is very precise, so it can't be compared to a CPU pin that was just repaired by a human regardless if it was meticulously repaired.
A bit of a tale here, around 3 weeks ago I bought a used 5950X for 312$, I bought it because it was so cheap for that kind of CPU. Tested everything that had to be tested and it was running fine, in addition it was also repaired by a guy whom I knew was very meticulous in his craft, hence I was confident to buy that 2nd hand CPU even though we didn't fully know the history of where he got it from.
Also as added assurance, he had a magnifying type of device that we used to inspect each individual pin so we can assure that the repair was done thoroughly. Anyways I brought it home and slapped it in my system, and the performance was great in games.
But the issue was there was a lot of micro stuttering in games that can be run easily. Frametimes were just terrible in some games like TF2, so I'm thinking maybe it was a bottleneck since I only play at 1080p and it was paired with a 6700XT. So as a workaround, I capped my FPS to smoothen the frametime a bit, still it stutters. So that's when I had the idea that maybe it was because of the pin.
Maybe the pins don't match the factory standards anymore so maybe that's why there is a performance issue. A lot of people will say, "if it boots then it's working fine", and they're not wrong. But what about small details like this? Almost for also that some of the pins were chopped off before the repair, so my guy had to solder some pins back.
Maybe this contributed to the issue since the pins soldered back were not factory pins anymore? So what do you think guys?
I opted for this to be a discussion instead of a question since I'm sure there's no definite answer to this. It depends on the case scenario really. Apologies for the long read. Can't really shorten this explanation, had to make sure every detail is out here so you guys can give a more informed feedback.
