I don't mind what brand it is, I just found some good looking cooler master cases.Why only cooler master?
What's your budget?
What are your system specs? (CPU & GPU)
Yes that's true, so if i replace the cooling, and possibly the case fans (for example be quiet fans), the case would not be such of a problem..right?If noise is your chief concern getting a premium model of graphics card (that has a good cooler) and possibly replacing the CPU stock cooler are probably going to make a bigger difference than your choice of case.
