Hi
Few days ago my PC shut down instantly in game menu (MW), but it was able to turn on normally, no bios resets, no burnt smell etc. I did a stress test with Furmark (cpu+gpu) for 1 hour, temps were fine (max 71°C on CPU avg 68, GPU 67°C) and nothing happened.
Yesterday, when tried to wake from sleep it stuck in a self check loop. It turns out it couldn't start at 3200Mhz XMP (RAM) only on it's stock 2666Mhz. After restart, appcenter update the firmware on its own (yes it was only said firmware) and "update" the bios to the stock F4 from F11 on both main and backup bios. I didn't want to diagnose at night so I turned it off.
Today before turn on, I heard a quiet moaring from the PC, the GPU and PSU fans were spinning at low speed, but the PC was off. CPU led was red after I stopped the blades by hand it started blinking and tried to spin the fans up again even if the power cables pulled off, so it get power from the PCI slot. Error code D4 (or 04, anyway it is the "PCI resource allocation error. Out of Resources. ") but it wasn't so bright as it used to. (Btw i realised the PSU fans were spinning too in eco mode, after start it turns off under low load)
After start, everything works fine, no CPU led after check, runs with XMP profile on 3200MHz. Did some driver reinstalls, latest bios update. Nothing wrong when it's running.
After shutdown all fan stop but the GPU fans keep spinning and the CPU led turns on, POST code: D5 ("No Space for Legacy Option ROM initialization" ) or! D0 ("CPU initialization error "). It changes after every shutdown.
If I turn the switch on the PSU off, then on, GPU tries to spin up, CPU led is on and a very dim 00 (probably D0) POST code appears. No buttons have pressed except he PSU switch.
What I have tried:
CPU: Ryzen 7 3700x
Cooler: Be Quiet Dark Rock Pro 3
Mobo: Gigabyte x570 Aorus Master
PSU: EVGA Supernova 850 P2
GPU: Gainward Phoenix GTX 1080
RAM: 2x8 Gigabyte 3200MHz
Case: Fractal Design Meshify S2 Dark TG
I know it is a bit messy how I describe it, but i hope someone can help. Pc works fine just it can't turn off completely, just only with the PSU switch.
No overclock, voltages were set to auto (yes it hits 1,48V but as you can see it tops at 71°C)
Update 05.28:
Next morning PSU switch on, GPU/PSU fans spin up, little bit faster for GPU. CPU led flashing, no visible POST code. Probably not enough power for it due to the GPU fan. Might be this is why the led is flashing?...
Could be a shortage in PSU or a bad Mobo? It is affected at the 24 pin.
After start every bedug light went out, PC works as is should be. Nothing happened at night during game
Utdate 05.29:
No CPU led after shutdown, just fan spinning. Probably out of juice. Next start same thing.
What I have tried:
- - Check if both bios works fine ✔
- - Check all power cables in the system ✔
- - Pull out every power cables from the system, except he 24pin
- --> CPU led on, PSU and GPU fans are spinning or at least the gpu tries to spin.
- - Get out the GPU and start the sys with cables connected (before start, CPU led)
- --> GPU led (obviously), no CPU led
- - Reseat the CPU
- --> same thing. CPU led and D0
- - Start without CPU (I know it's not a good thing)
- --> CPU led (obviously), constant rapid on-off loop
- - Bios reset, new bios ✔
- - Check the PSU on it's own. Short the green-ground wires
- --> Click sound, like when it's turn on but no fan spinning
- - Pull out the case pwr switch from mobo
- --> No changes
- - Every cables plugged in, except 24pin
- --> No LED, no fan (GPU, PSU)
- --> Plugged in the 24pin --> CPU led, fan spin (GPU, PSU) and dim POST code
- Reseat the memory sticks, but it every time pass except the first time from sleep.
- New PSU, currently I don't have in spare
- New CPU, same
- New Mobo, same
- PSU failure (voltages are fine even under stress test)
- Motherboard failure
- CPU failure
- I tought it might be corrupt bios at first time, but after update i don't think so.
CPU: Ryzen 7 3700x
Update 05.28:
Utdate 05.29:
