Hello!
I really hope someone can help me, I’ve spent the entire weekend testing out options to why my monitor won’t display my pc.
My issue started with having Windows 10 not loading my programs, if I would click on google chrome or photoshop, for example, it would automatically shut down my computer, so I decided to reformat and do a fresh install of Windows 10, and the same problem occurs. So what I ended up doing was going into the case and made sure that the GPU was properly seated because it tends to drop a little due to the liquid cooling and fittings beneath it and once I did that the computer shut off and I started to smell a little smoke but very faintly. When I went to boot up the pc, it would seem to boot up normally with all the LED lights on, as well as the Asus motherboard displaying the ‘Q code A0’ which should be normal from what I see, but yet won’t show any sign of video that should be displayed on to my two monitors. I am using two display port connections from my GPU to my two LG Monitors, which both use DVI connections.
I’ve tried everything.. from removing all the RAM sticks to just one, took out all the tubing for my liquid cooling loop to get to the GPU and remove that and checked the pins, everything looked normal. Even changed the PSU connection to another socket, nothing... I even did the basic step of resetting the CMOS by removing the battery and jumper on the 3 pins, nothing. I also tested out the secondary PCI-Express slot with an older PCIe Nvidia card connected to another monitor, and nothing.. I’m really stuck!
I believe the problem is in the BIOS, since I reset the CMOS, I believe that the CPU is forcing the onboard video card to project the display, unfortunately, I can’t connect to it since the only option to connect to is with a USB Type-C connector which I did test out with a digital drawing tablet display Type-C connection with no luck. I could probably switch the bios from using the onboard display to using the PCIe display. But how can I achieve this without seeing anything on the monitor? I’ve tried tapping the delete key when restarting along with the F2, and F10 key with no luck. I can tell that it boots properly on to the windows OS because all my USB components go on about 10 seconds into the boot.
Here are my specs:
Case: NZXT h700i
Mobo: Asus Strix X299-E Gaming
Ram: 4x 8gb G-Skill (32)
SSD: Samsung 970 M.2 1TB internal SSD
GPU: Asus RTX Strix 2080 TI
PSU: Corsair HX 1200i
CPU: Intel Core i9-7920X 12 core
Please if anyone can assist me, I would greatly appreciate it!
Pics:
Here are my specs:
Case: NZXT h700i
Pics:
