Hello,
This is probably a very rookie question but I'd rather ask the experts instead of blowing up my PC!
I purchased a Thermaltake View 32 Case and the case comes with 3 pre-installed RGB Fans from Thermaltake that are all connected to an RGB Hub / Switch. So far all good...
Although off that switch is a power cable that goes into a female and male molex cable - no adapter of any sort is included in the box and obviously without the power the fans do not spin.
Can anyone recommend me some sort of adapter that I can use to power that RGB switch? I did some research and I think molex to sata is the one but does it matter which side I use? (male or female)
Some photos for better understanding
Thank you in advance for any help
Matt
Matt
