Hey so I bought the Corsair SPEC-DELTA RGB case which comes with 4 fans, 3 of which are RGB. All 4 fans use 3 pin connections. The problem is, my mobo is the B450M PRO-M2 MAX which only has one SYS_FAN fan header. So using splitter isn't really an option as the power usage would likely be too high for one header and hubs don't seem to be able to control speed for 3 pin connection as they only support PWM speed control. I saw that the Phanteks PH-PWHUB_01 might be a good option but it's unavailable atm.
What should I do to power all fans while still having the option to control their speed?
Also, buying new fans or a new mobo is not an option for me.
