Hey there,
I recently received a new nvidia 2060 super 8gb Founders edition as a replacement from Nvidia and it worked fine for 1 day. Drivers installed properly, games worked fine and everything.
On day 2 while playing some forza, random artifacting started (it froze with artifacts and a loud buzzing sound from the headphones). I did a DDU uninstall of the GPU Drivers & reinstalled them. Games worked fine mostly. I also thought i'd try to run heaven for a stability test. It worked fine for few seconds and i got artifacts again. I did a restart and tried heaven again. It worked fine until I moved the mouse input. Artifacts came back.
I gave up because it was late night and I turned off the PC. Next day I turned it on and now I have artifacts and weird lines (pic attached) even on idle. Not just while GPU is on load.
Also another weird thing is that the GPU doesnt show artifacts if I change resolution to anything below 720p. Only resolutions above 1024 and 1080 show artifacts.
Also there is some weird sound coming from my PC when I move my mouse. It comes from the back of the PC but I cant tell from where exactly. How do I fix this?
Some possible things I think could be happening:
Things I've tried:
-tried different hdmi cable
-DDU & fresh driver install (when screen flashes during driver install, it artifacts)
-Reseated GPU/RAM
-Tried another GPU which doesn't artifact
-Updated motherboard bios
setup:
Ryzen 7 3700x
Gigabyte X570 Aorus Ultra
RTX 2060 Super FE
8GB x2 16GB Gskill Trident Z RGB 3600Mhz
1TB & 250GB SSD, 2TB HDD
Corsair RM750 2019 PSU
- GPU is faulty yet again. Even though its RMA one.
- Some part in the system (either motherboard or PSU) is causing the GPU damage? Could it be a motherboard short or a bad PSU
Things I've tried:
-Reseated GPU/RAM
setup:
Ryzen 7 3700x
RTX 2060 Super FE
