I have a Gigabyte GA-990FXA-UD3 v1.2 motherboard with AMD with 4 x 4 Gb DDR3 RAM.
(https://www.gigabyte.com/Motherboard/GA-990FXA-UD3-rev-12)
Under higher performance (CPU or memory intensive operations, or long disk copy operations)
the Northbridge of this board is overheated reaches 80 °C, then the motherboard starts beeping.
Happened error events:
Now, after a week the computer boots well, with same videocard, same 4x4 RAM modules, same power supply.
Based of these symptoms I predicted, power supply problem or Northbridge overheat problem.
I tested with another power supply, the configuration worked well.
So I ordered a new power supply.
Before I test the new power supply, I wanted to test again the motherboard, to reproduce the errors again, before using the new power supply.
Strange, that the board booted well, I was able to insert the GT-9600 videocard, the 4x4 Gb RAM, the boot successfully.
RAM tests went well, booted into Hiren's Boot CD, tested memory in Windows mini XP, and some stress tests, all successfully.
Then attached the 2 x Areca ARC-1210 RAID card, attached 2 x SSD + 2 x HDD (both with RAID1 volumes).
Booted well into Windows 7 Pro.
I used then OCCT stress test tool (https://www.ocbase.com/), which showed 80 °C at Northbridge, and the started beeping at this time.
I don't know how I got videocard & RAM error beeps at boot, then after a week it boots well, while nothing is changed.
Anyway, the Northbridge overheating is still problem.
I have to change the Northbridge thermal paste for sure.
I will likely keep the power supply in case the old power supply still dies.
My questions:
1) May Northbridge overheating be responsible for all such strange symptoms and errors?
2) Could you skip the power supply as problem source, or should I still count with this possibility?
3) Which thermal paste to use? Arctic Silver 5 Thermal Grease? Is it safe to use?
I did read, that AS5 (Arctic Silver 5 Thermal Grease) is good for Northbridge, because it is not electrically conductive.
Is it safe to use?
4) Or do you recommend something other?
5) Should I replace thermal grease on all heatsinks, including Northbridge, Southbridge, MOS heatsink (above CPU)?
6) Should I use Arctic Silver 5 Thermal Grease on all of them?
Thanks!
- Random BSOD sometimes.
- It happened to get long beeps at boot, when using Gigabyte GT-9600 videocard, while using a low performance card, booted without error.
- It happened to get long beeps at boot, when using 4 x 4 Gb DDR3 RAM, while using 2 x 4 or 3 x 4 Gb DDR3 RAM, booted without error. There was no problems with these 4 x 4 Gb DDR3 RAM modules, which was used since a few years. I replaced the modules randomly to boot well with 3 x 4 RAM modules. Also made memory tests with 3 x 4 RAM modules. So I made sure, the memory modules are good.
My questions:
Is it safe to use?
Thanks!
