[SOLVED] What is the best way of powering the GTX 770's 6 pin and 8 pin power inputs from a single 6 pin and 3 spare molex cables from my PSU?
May 15, 2020
I'm upgrading the GPU in my HP Pavillion h8-1170uk (sorry).
I bought the GTX 1660 only to find out my mobo isn't compatible thanks to the lack of UEFI Bios. With this in mind, I'm trying to find a non-UEFI compatible card that will run on a 460w PSU. I'm also wanting 4GB of GDDR5 for some of the latest games, mid res I know, so I'm currently looking at the GTX 770 4GB.
Should I get a molex adapter to 6 or 8 pin? With a 6 pin molar adapter, I would need to use a 6 to 8 pin adapter for the PCIE cable.
Anything would be really appreciated
If your PSU does not have the proper connections for the desired GPU, you need a new PSU that does have the proper connections.
Do NOT use MOLEX adapters for this.
The card only requires a 450w PSU... what's the worst-case scenario if I did use adapters and it went wrong?
Short the PSU meaning I'd need to get a new one?.. or total system failure?
