Hi!
So yeah... My old B450 motherboard gave up and I really needed the PC so I quickly bought a x570 board that fitted my connectivity requirement... And that's how I got the Msi X570 A Pro.
Anyways, since I have a x570 board now, why not upgrading to a better CPU:
Currently I'm running a Ryzen 7 2700.
What do I do?
-Gaming (1440p /w RTX 3060)
-Blender (Rendering & Fluid sims)
-Adobe Photoshop, After Effects and Premier
-Coding (Python)
I'm doing pretty much 50% gaming and 50% productivity.
What CPU am I considering?
Ryzen 9 3900x or a Ryzen 7 5800x
My Problem:
I know that the VRM's of the X570 A Pro are horrible. But most of the tests on the world wide web are open test benches with some sort of overclocks.
Although I won't be having such an environment. First, if I would pick the 3900x I would use the Wraith Prism cooler (Top blow cooler). Secondly, if I picked the 5800x I would probably buy the be quiet! Dark Rock TF cooler (top blow aswell).
My airflow isn't bad either: one 120mm fan in the back and two 120mm at the top pulling air out of the case. (Aswell as 2x140mm and 1x120mm fans in the front for intake)
Everything is going to be stock. I won't do any kind of OC.
Back to the question:
Will it throttle the 3900x/5800x or not? Imo it should definitely be enough, but most reviewers overexaggurate the VRM temps as a "massive problem".
Also, I cannot decide which cpu to pick, so this will be one big factor for my upgrade path
Thanks for your advice
What do I do?
-Coding (Python)
My Problem:
