KevNaja Jul 12, 2020 7 0 10 Jul 24, 2020 #1 I'm planning to buy the Coolermaster Masterliquid ML240L but I don't want to have the radiator fans have its LED turned on. Will the fan work perfectly if the RGB wire is disconnected from the header?
Solution Lutfij Jul 24, 2020 Yeah, so long as the RPM wires are plugged in but the RGB wires unplugged, you should be good to go!
Lutfij Titan Moderator Oct 7, 2009 61,455 6,852 178,440 Jul 24, 2020 Solution #2 Yeah, so long as the RPM wires are plugged in but the RGB wires unplugged, you should be good to go! Upvote 0 Downvote Solution
