[SOLVED] CORSAIR Carbide Series SPEC-DELTA RGB Control?
RyanTodd1
144
Hello Guys,
Thinking of purchasing this case for as on a bit of a budget, however i am unsure how the RGB fans work due to there being no controller and the Corsair website specifying that the RGB can be controlled by software on Mobos by MSI, ASUS and Gigabyte. Unfortunately, i have an ASRock Z370 Pro Mobo so im not entirely sure where i stand with the case.
Any thoughts/ideas?
Thank you,
Ryan
This case is working with a 12V 4pin RGB header on a motherboard.
Your motherboard does not support RGB directly, it doesn´t provide RGB headers.
You will need a RGB controller, which would be connected via the USB header on your motherboard, like:
View: https://www.youtube.com/watch?v=vjvZJrNxyyw
Good Afternoon,
Thanks for your reply.
Is the software supplied with the hub or free online?
Thanks,
Ryan
