Crazy Temps when Intake Case fans are on RX580(PowerColor Red Devil Golden Sample) and HDD(Seagate Barracuda 2TB 7200RPM, 128MB Cache)
During Gaming temps are 80-85C on GPU and 46-47C on HDD (When intake fans are on Temps increase when intake fans are off temps reduce)
Idle GPU on 40C(Fan stops spinning) CPU on 30C and HDD on 39C
Ambient Room temp is 32C
I have a Chiptronex Raptor RGB Case
flipkart.com/chiptronex-raptor-rgb-tempered-glass-atx-gaming-cabinet-without-smps/p/itmfaf9rgczmxsnb
View:
View: https://www.youtube.com/watch?v=T8I2nv2W2ps
This is how it looks
It came with 3 Front intake and and 1 rear exhaust I had added 3 Static RGB 120MM fans(Random ones form Aliexpress it says 50CFM) on top
I have a Snowman M-T6 mounted on a i5-4590 in an orientation where the fans pull air from bottom to top because my Mobo(Biostar H81MHV3) wont allow me to fit it left to right RAM clearance issue also fitted the rear exhaust outside the case and flipped it and using it as intake due to the same clearance issue the case do not have enough space to fit the fan inside after using the cooler
so I have 1 rear sending air to the CPU Cooler
3x front intake
3x top exhaust
all 120mm fans
the top exhaust all 3 are always running and I have a button to turn on or off the rear and front fans so when I turn them off the GPU temps decrease(runs cooler by 3-4C) and when I turn on the front 3 intake and rear 1 intake GPU temps increase(runs 3-4C hotter) I have no idea why and what to do I also stuck a stick and stopped the rear intake and let only the 3x front intake and 3x top exhaust run and I still got the same problem but with a small change the GPU temps raised by only 2-3C
So running the read intake increase GPU temp by 1-2C and runing the 3x front intake increases the temps by 1-2C
My ambient room temp is 32C i live in Pondicherry sount east India the city is mostly hot all the time
Also my HDD temps alo goes to 46-47C when GPU load is high during idle HDD temp is 38C.
Also the case says it supports 320mm rad on top and front but it cant fit any radiator anywhere because this stupid case do not have enough clearance between the mobo and the top (even the top exhaust fans are almost touching the mobo) and also the screw holes and the space(width of the case) do not seem to fit any AIO the space is very less.
The pics of my PC are in the below links
*Pics are taken with side panel off but I always leave the side glass panel on and all the info shared above are the temps with side panel on.
https://drive.google.com/uc?id=1ku_ZVJucMJ6vzrYpxx7YQYfm5wkRf-Qd
https://drive.google.com/uc?id=1t18uUyIOWrVhzZii9gxY0BHsEUeVAXOC
https://drive.google.com/uc?id=1wfPFKCzIW9GrB5nZMxcF6HlUW0Tti6qM
https://drive.google.com/uc?id=1PywgSJgXlpVmb3EQNLBYIZLY0YySS09u
https://drive.google.com/uc?id=1DIiPG2HhWAMBQR0wrUDJLa_QWq0QGdKn
https://drive.google.com/uc?id=1-fkUeaU9nORpuuSD5jbt84H1y36p2IKR
https://drive.google.com/uc?id=1mtCi_DrZIzwDV2xkWReRttzJn-7W_QM2
https://drive.google.com/uc?id=1Fct3ghDoo4KEhMZEYP1htWVtX-x8gPKS
https://drive.google.com/uc?id=1savQ7029i4Yqd7sgPII8hlYksiJPc1Q1
https://drive.google.com/uc?id=1tmSRcAM5HbKgtinJ45xR3jFhoG3iDOpF
https://drive.google.com/uc?id=12AlRJLCZp1ncLbRvc15cOTuULB4aOy0q
https://drive.google.com/uc?id=1AjH64hFQmdxJlyRkYQxSwOGt-hZg-FEg
Please advise me some ways to fix this I want the GPU and HDD temps to get lower when all fans are running than when they are not running
View:
3x front intake
3x top exhaust
all 120mm fans
