Question I keep experiencing high gpu latency (100+ ms) how do i fix?
Sep 17, 2024
29
When I play gpu heavy games, everything runs smoothly around 90 fps but sometimes I get massive fps drops (90 average to 15 average), when that happens, the bottom left corner of the screen says I have very high gpu latency (100+) and this lasts for about 10 long seconds. I have tried about everything there is to try, does anyone have suggestions? My exact build: GL704GM
From another post that I just responded to:
There are things you can do.
Use Task Manager and Resource Monitor to observe system performance.
Use both tools but only one tool at a time.
Another tool that can be used is Process Explorer (Microsoft, free).
https://learn.microsoft.com/en-us/sysinternals/downloads/process-explorer
Open the tool window and position the tool window somewhere on the screen or even on a second monitor if possible. Leave the window open and simply do nothing for awhile - just watch what the system is doing or may be trying to do.
Then, leaving the tool window open, open cs2 and play as you usually do. Watch the tool window.
Objective being to discover what changes when FPS drops. What system resources are being used, to what extent, and what is using any given resource.
It will require some time and effort on your part to get a sense of how to set up the screens and watch for changes. Graphical views are likely to show some peak or valley relevant to the FPS changing.
FPS drops could be due to some background app trying to update, backup, or maybe just "phone home".
Possibly being launched at startup or later via Task Scheduler.
There is no need to rush or make any immediate changes. Look for repeatable patterns that you can control making the FPS drop.
Remember you can take screenshots and post screens here via imgur (www.imgur.com).
