I bought a new GPU 2 days ago, i went after it and asked a few people as well to avoid any problems.
My old pc build:
-asus h110m-a motherboard
-8gb ddr4 2133hz ram
-core i5 6500 3.2 ghz
-gtx 950 2gb
-deepcool de430 (300w) (peak power 430) psu
-120gb ssd
-1tb hdd
I upgraded my gpu to a gtx 1660 6gb ddr5, my only concern was my power supply because i knew that it might cause future problems with lower wattage power. I have also read about the possible bottleneck of the cpu but it semmed minor. I made a couple tests, heaven furmark etc. It seemed like there were no overheating nor ram and gpu problems. On the other hand my cpu went up to 90-98% in a couple games. Suddenly it started to make a weird ticking loud noise so i quickly turned it off. I tried to reboot, it powered up but the fans on the cpu were struggling so i just left it there. Im not sure if the cpu or the motherboard or the psu had the problems. Is it possible that i overstressed the cpu or just the psu is not enough? I would be glad if someone could help!
My old pc build:
-gtx 950 2gb
-120gb ssd
-1tb hdd
