[SOLVED] I want to build a good gaming computer within a price range and I don't know if my parts are compatible. Pls help.
Mar 29, 2020
28
So I decided to go with:
Ryzen 5 3600x
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Asus ROG STRIX B450-F GAMING ATX AM4 Motherboard
G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory
Samsung 860 Evo 500 GB 2.5" Solid State Drive (SSD)
Seagate BarraCuda 1 TB 3.5" 7200RPM Internal Hard Drive
Gigabyte GeForce RTX 2070 SUPER 8 GB WINDFORCE OC 3X Video Card
NZXT H510 ATX Mid Tower Case
EVGA BR 500 W 80+ Bronze Certified ATX Power Supply
Total price: $1172.86
So I'm not sure if all of this is compatible and if I could make some better choices. I don't want to go with a higher price than this, so if anyone can help me or if you have suggestions, I'm listening..
If I forgot anything, pls hmu
PCPartPicker Part List
Type|Item|Price
CPU | AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor | $298.99 @ Newegg
Motherboard | MSI B450-A PRO MAX ATX AM4 Motherboard | $99.99 @ B&H
Memory | G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3200 Memory | $69.99 @ Newegg
Storage | Crucial P1 1 TB M.2-2280 NVME Solid State Drive | $109.99 @ B&H
Video Card | EVGA GeForce RTX 2060 6 GB XC GAMING Video Card | $302.98 @ Newegg
Case | Corsair SPEC-05 ATX Mid Tower Case | $48.98 @ Newegg
Power Supply | Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply | $69.29 @ Newegg
| Prices include shipping, taxes, rebates, and...
Ryzen 5 3600x
If you ise pc part picker it will tell you if the parts you are building are compatible however the build you just described is mine to a t basically and you should be good getting no less then 120fps in overwatch max settings
Ryzen 5 3600x
My build
Asus rog strix b450-f gaming
Ryzen 5 3600x
Geil evo "2x8gb" 16gb ram
Rtx 2080 ssc 11gb black
120 m.2 boot
1tb m.2 storage
1tb ssd
1tb ssd
4tb hdd
2tb hdd
I used one and it said: Warning! Some AMD B450 chipset motherboards may need a BIOS update prior to using Matisse CPUs. Upgrading the BIOS may require a different CPU that is supported by older BIOS revisions.
If the budget is around $1200 this is what I'd get.
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($248.50 @ Vuugo)
Motherboard: ASRock B450M/AC Micro ATX AM4 Motherboard ($107.92 @ Vuugo)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory ($99.99 @ Newegg Canada)
Storage: ADATA XPG SX8200 Pro 256 GB M.2-2280 NVME Solid State Drive ($79.99 @ Memory Express)
Storage: Seagate BarraCuda 1 TB 3.5" 7200RPM Internal Hard Drive ($57.95 @ Vuugo)
Video Card: Gigabyte Radeon RX 5600 XT 6 GB WINDFORCE OC Video Card ($389.99 @ Memory Express)
Case: Phanteks ECLIPSE P350X ATX Mid Tower Case ($99.99 @ Newegg Canada)
Power Supply: SeaSonic FOCUS 650 W 80+ Gold Certified Semi-modular ATX Power Supply ($104.99 @ Newegg Canada)
Total: $1189.32
Generated by PCPartPicker 2020-03-29 16:21 EDT-0400
Total: $1189.32
idk if the ssd is good enough cus mw alone is about 200 gb, and no cooling? is the cooler that comes with the cpu enough?
Does it need to be on the SSD?
If so then adjustments can be made...
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive ($142.50 @ shopRBC)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive ($69.99 @ Memory Express)
Video Card: Zotac GeForce GTX 1660 SUPER 6 GB GAMING AMP Video Card ($318.50 @ Vuugo)
Case: Fractal Design Focus G ATX Mid Tower Case ($73.50 @ Vuugo)
Total: $1165.89
Generated by PCPartPicker 2020-03-29 16:34 EDT-0400
Total: $1189.32
also, I didn't previously build a pc or anything, but is the Radeon RX 5600XT better then the nvidia gtx 1660ti?
Total: $1165.89
idk.. what should i have on the ssd (other than windows)? I dont need 1tb of ssd and 2tb of hard drive, like 500gb ssd and 1 tb hdd is good.
Depends on load times, the game should be on a SSD if the loading times are so long that you start later then other players, I wouldn't know as I don't play that game. When I played the later BF series the games were pretty much required on a SSD or the match would start without you.
the match starts without me sometimes, and its really annoying, especially when you have trash and dumb teammates and you get a bad beginning, the match could be a loss because of the start
Games like CSGO won't be an issue to keep main files on hdd, as all the files will cache through the ssd first. It's only the original map load that takes a little longer, but after that it's cached, so runs at ssd speeds. Fps in CSGO is highly map depending, original maps like Office, I get @ 300fps with an i7-3770K and gtx970 at ultra, but newer, user designed maps can drop that to @ 120fps, due to higher graphical intensity and a ton more background objects.
