Yo, I'm having a problem getting the rated 3200MHz out of my 'Corsair Vengeance RGB (4x32GB)' on a new BIOS revision where previously everything was fine. I have an ASUS ROG Rampage VI Extreme and XMP was working fine with BIOS 2002; however, after updating to 3006, I cannot get my RAM to boot into Windows at 3200MHz no matter what I try. I've tried manually inputting the timings printed on the DIMMs, which is 16-18-18-36 at 1.35V. I've then tried bumping the DRAM voltage to 1.4V with no joy, then VCCIO/VCCSA up to 1.20V, then loosening the timings a bit but I'm getting that same annoying red LED letting me know the motherboard is not booting past RAM. I am able to boot into Windows with a maximum frequency of 2800MHz, stable, with the rated timings and voltage.
Can anyone suggest anything else that will solve this problem? This motherboard has had memory problems (QCode AF: Detect Memory) right from initial purchase, and XMP has never worked without me adding more voltage even when it was working, but I had managed to get it stable on the previous BIOS revision. I think if I get this sorted I'm going to stay with this BIOS until end of life. 😵
Over and out . . .
Over and out . . .
