Question need help with cpu
Feb 19, 2023
4
Hello people, I've upgraded from a Ryzen 3 2200G to a Ryzen 5 5600G. I have this on a MSI B450 Pro-M2 mobo, which is, according to Google and people on forums, compatible with my cpu. I installed the new cpu on my mobo, and it won't work. I checked everything, everything's powered and I updated my bios (forgot the version, could post it if people need to know). People here on reddit said it would be fine. After all this it still won't work. I plugged my old cpu in, and it worked fine. Help!
Also, be sure to read EACH BIOS updates notes BEFORE you install them to be sure whether there is a bridge BIOS (one that needs to be installed first) before than final version.
Aside from that, did you source the new CPU as new, or used?
i couldnt find anything on this, so i think not?
the cpu is brand new, got it in last friday.
