Thundurh
177
Hello. Whenever I play games my 980 Ti is in the 75-80 C range. Is that too hot? I would like to know how to decrease these temps if so! Thankss
So you've got the three 120mm fans in the front as intake, and a rear 120mm exhaust?
Can you remove the side panel from the case and run it again. Note if/what temp differences you see in that config. Could also try this with the front panel removed and the side panel on.
Not alarmingly high.
What is the fan speed on the GPU.
What case do you have?
What fans are installed? (size and direction of airflow (intake/exhaust).
Do you have an AIO CPU cooler? If so, where's that installed?
Fan speed idle is at 20%, under load it goes up to around 90%
My case is an CORSAIR Carbide Series SPEC-DELTA
Fan installed are just the fans that came with the case. The front fans are sucking in air, and the back ones are blowing out air.
I have a Cooler Master Hyper 212 EVO CPU cooler
