[SOLVED] PC upgrade, what parts to get?
Depends on your resolution. If you want to go for 1080p, these cards should be fine. Just know that the 1660Ti > 1660 Super > 1660:
GTX 1660:
https://pcpartpicker.com/product/MY...tus-xs-oc-video-card-gtx-1660-ventus-xs-6g-oc - Twin Fan - $214.24
GTX 1660 Super (Single Fan):
https://pcpartpicker.com/product/By...r-6-gb-black-gaming-video-card-06g-p4-1061-kr - Single Fan - $213.98
GTX 1660 Super (Twin Fan):
https://pcpartpicker.com/product/Z3...-xs-oc-video-card-gtx-1660-super-ventus-xs-oc - $224.99
GTX 1660Ti (Single Fan)...
I think you really need to save up more. 200USD isn't enough for a decent upgrade.
With just a 200USD budget:
A Ryzen 2600 + a B450 mobo is around 2-4% slower than your i3-8100 - EXCEPT! Except in games that use more than 4 cores/threads, then the Ryzen 2600 pulls ahead.
Ryzen 3600 would be better, but it's well out of your budget.
The GTX 1650 Super and RX 580, the strongest options within your budget, are around 2-8% uplift on average over your current gpu.
Those gains are not good within that budget.
What if I were to bump up my budget to about $250? Any good options that'd last some time?
Speed? With 16 gigs of RAM at 3000 Mhz +, you should be able to reuse it. Unless it is at lower speed, then performance will be impacted.
PCPartPicker Part List: https://pcpartpicker.com/list/kJDNr6
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($174.99 @ Amazon)
Motherboard: Gigabyte B450M DS3H Micro ATX AM4 Motherboard ($72.98 @ Amazon)
Total: $247.97
Generated by PCPartPicker 2020-03-18 21:08 EDT-0400
Just be aware that some B450 motherboards need a BIOS update before putting in a Ryzen 3rd gen processor, but manufacturers should be shipping them out with the latest BIOS now days.
Reactions: Phaaze88
Total: $247.97
What if I were to go for a graphics card? What should I get?
