Hi all,
I know there are some similar discussions(which I’ve read) to this post. So apologies for that, just wanted to get some extra input on my situation in case anyway had some tips I had not thought of.
About a month or two ago, my pc(5+ year old build) finally kicked the bucket during use. Black screen, not blue. Took a break from pc but can’t any longer. It had occasionally powered down before on its own, but would always start back up with a light adjustment of the 24pin power connector to mobo. This time it will not boot at all.
Instead of taking the situation wisely, I admittedly just tried to power on my pc again(when this first happened months ago). After an attempt of this, I smelled a burnt smell from the inside of my case. And saw a teeny bit of smoke coming off the GPU itself. I switched off the power, unplugged, drained the power, and removed the GPU. GPU itself doesn’t appear to have any damage minus dust buildup which accumulated over the years. PCIe slot also looks undamaged.
When I plug my system into power, I see a green light appearing on my mobo but know that probably doesn’t mean much in terms of its functionality. When I try booting without my GPU installed(to test integrated graphics), the PC refuses to give any sign of life whatsoever.
Please note I didn’t have my PC actually plugged into a display during these tests, I figured it would spin fans at least before it shows a display. Should I plug into a display when testing this? Or does anyone think I should be testing in another manner?
I’m just not really sure where to start and a bit discouraged from the fact that booting before seemed to give off smoke. I really do not want to break any more parts than I already have(not sure that I did even). Money is tight for now.
I was planning to clean the system fully, removing any cables from the mobo, and re-inserting them to test. After that, not sure how to test. Should I remove my RAM sticks? Try new RAM slots? I don’t have a different PSU to test with, but I’m starting to wonder if this is the issue now. And would there a be a most appropriate order to test these things in ?
Any help or ideas are greatly appreciated. I very much miss gaming and enjoying my hours on it. I haven’t tried anything other than what I stated. All purchased from 2015, Here are some of the main specs of my build:
Motherboard: Asus Z170-A
CPU: Intel i5 6600k
GPU: msi GeForce GTX970 4GD5T
PSU: RAIDMAX VAMPIRE RX 800W GOLD
RAM: Corsair Vengeance DDR4(8gbx2)
Basic case fans, cooler master on cpu, etc.
CPU: Intel i5 6600k
