Question How much ARGB fans can I connect to SATA power supply output?
Apr 2, 2020
good evening to everyone,
I have a cable that has 4 SATA with a single 6 pin output from the power supply. I have 8 ARGB 2300 rpm PWM fans, 1 PWM splitter (SATA power), 1 ARGB splitter (SATA power), HDD (SATA power) and the AIO pump (SATA power). Can I connect everything with that cable described at the beginning? Can the SATA output of the power supply support all these components?
Thanks in advance.
Good evening everyone,
Can I control the effects of the ARGB LED lights both with the mobo software and with an external switch positioned on the front panel of the case?
Thanks in advance.
