My problem would be that for some reason I have an input lag and it's only and I looked in this program and it's because of 2 things
LATENCY MON
_
CONCLUSION
_
Your system appears to be suitable for handling real-time audio and other tasks without dropouts.
LatencyMon has been analyzing your system for 0:15:03 (h🇲🇲ss) on all processors.
_
SYSTEM INFORMATION
_
Computer name: DESKTOP-BGN9TEQ
OS version: Windows 10, 10.0, version 2009, build: 19045 (x64)
Hardware: MS-7A62, MSI
BIOS: 1.70
CPU: GenuineIntel Intel(R) Core(TM) i5-7400 CPU @ 3.00GHz
Logical processors: 4
Processor groups: 1
Processor group size: 4
RAM: 16343 MB total
_
CPU SPEED
_
Reported CPU speed (WMI): 30 MHz
Reported CPU speed (registry): 30 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
_
MEASURED INTERRUPT TO USER PROCESS LATENCIES
_
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 287,0
Average measured interrupt to process latency (µs): 4,111537
Highest measured interrupt to DPC latency (µs): 284,40
Average measured interrupt to DPC latency (µs): 1,497546
_
REPORTED ISRs
_
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 260,381333
Driver with highest ISR routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0,12020
Driver with highest ISR total time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in ISRs (%) 0,123882
ISR count (execution time <250 µs): 352267
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 1
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
_
REPORTED DPCs
_
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 402,299667
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 526.98 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0,141104
Driver with highest DPC total execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 526.98 , NVIDIA Corporation
Total time spent in DPCs (%) 0,277097
DPC count (execution time <250 µs): 877266
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 275
DPC count (execution time 1000-2000 µs): 0
DPC count (execution time 2000-4000 µs): 0
DPC count (execution time >=4000 µs): 0
_
REPORTED HARD PAGEFAULTS
_
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: msmpeng.exe
Total number of hard pagefaults 3143
Hard pagefault count of hardest hit process: 1369
Number of processes hit: 27
_
PER CPU DATA
_
CPU 0 Interrupt cycle time (s): 19,318316
CPU 0 ISR highest execution time (µs): 260,381333
CPU 0 ISR total execution time (s): 4,439468
CPU 0 ISR count: 328835
CPU 0 DPC highest execution time (µs): 402,299667
CPU 0 DPC total execution time (s): 9,035001
CPU 0 DPC count: 687484
_
CPU 1 Interrupt cycle time (s): 2,310716
CPU 1 ISR highest execution time (µs): 98,086667
CPU 1 ISR total execution time (s): 0,03580
CPU 1 ISR count: 23242
CPU 1 DPC highest execution time (µs): 288,240333
CPU 1 DPC total execution time (s): 0,656591
CPU 1 DPC count: 77606
_
CPU 2 Interrupt cycle time (s): 1,679575
CPU 2 ISR highest execution time (µs): 6,1620
CPU 2 ISR total execution time (s): 0,000509
CPU 2 ISR count: 191
CPU 2 DPC highest execution time (µs): 125,853667
CPU 2 DPC total execution time (s): 0,187108
CPU 2 DPC count: 70603
_
CPU 3 Interrupt cycle time (s): 1,391559
CPU 3 ISR highest execution time (µs): 0,0
CPU 3 ISR total execution time (s): 0,0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 37,2890
CPU 3 DPC total execution time (s): 0,132664
CPU 3 DPC count: 41848
_
LATENCY MON
_
CONCLUSION
_
_
SYSTEM INFORMATION
_
BIOS: 1.70
Processor groups: 1
RAM: 16343 MB total
_
CPU SPEED
_
_
_
_
REPORTED ISRs
_
_
REPORTED DPCs
_
_
_
_
PER CPU DATA
_
_
_
_
CPU 3 ISR count: 0
_
