[SOLVED] Request advice regarding 2 PCs specifications - adjusting the components and preventing bottlenecks
Sep 11, 2021
5
Hi everybody,
  • I'm asking for your opinion and advice regarding the two computer specifications listed here, especially in relation to adjusting the hardware components and preventing bottlenecks.
  • One computer is more standard and the other more powerful, the emphasis here is on reliable computers with a minimum of malfunctions and durability for a period of at least 5 years.
PC 1: Designed for browsing, easy graphic editing and storing its products
CPU:
intel - i5 10500
CPU COOLER: Arctic Freezer 7X CO
MOBO: MSI B560M PRO VDH
GPU: ASUS GT 1030 Low Profile 2GB GDDR5
SSD: Samsung 970 EVO PLUS 250GB NVMe M.2
STORAGE: WD Blue 2TB 256 MB 7200RPM SATA III
RAM: Kingstone Fury Beast DDR4 2666Mhz 2x4GB
PSU: Antec NEO ECO GOLD Zen 500W
BOX: Corsair SPEC-05 Window Mid Tower
PC 2: Designed for graphic editing and easy gaming
CPU:
intel - i7 10700k
CPU COOLER: Noctua NH-D15 OR Scythe Fuma 2
MOBO: Gigabyte Z490 AORUS ELITE AC OR GIGABYTE Z490 AORUS Xtreme
GPU: Nvidia GeForce RTX 2080 Super 4GB
SSD: Samsung 970 EVO PLUS 500GB NVMe M.2
STORAGE: WD Blue 4TB 256 MB 7200RPM SATA III
RAM: G.Skill Trident Z Neo RGB 2x8GB DDR4 3800Mhz
PSU: Corsair 650W 80+ GOLD RM650X
Thanks for your help
The second one should be a good match. Although you might want an RM750x. For a bit more headroom for overclocking.
As for the first one. It depends on the uses. For general usage. It's fine. But for GPU intensive tasks. Such as gaming. There's definitely a mismatch between the GPU and CPU.
Personally, I'd double the RAM on each build. As they're a little light.
Hi everybody,
CPU:
intel - i5 10500
CPU:
intel - i7 10700k
I don't think either one is more prone to failure than the other.
This comes down to what do you want to do with the machine.
PC1 is for my mom - mainly use for browsing and pictures editing.
PC2 is for my home - mainly use for browsing, Ps CS6, "light" gaming and some cad drawing.
thanks again :~)
What kind of gaming does your mom do? If her usage is anything like my mom's, a discrete GPU may not be necessary (my mom does have a GTX 1070, but that's only because I always have a lot of parts just hanging around).
The one for gaming is not for my mom, it's for my home. Her old pc was built, 9 years ago, with i3 2120 3.3Ghz and no gpu. This time, after all those years, i thought it will be better to add a gpu to the list.
