My gpu Zotac Rtx 2060 6gb GDDR6 is making weird fan noise (buzzing, clicking and some sort of crunchy noises) it is also giving off some weird plastic smell while both idle and and during gaming (it also gave some burning smell a few days ago), the fans rpm doesn't go beyond 400 while both idle and gaming (Gpu-z shows fans were on 400 rpm while fans were running on 100%) and casuing overheat upto 87 to 89C (the hotspot on Gpu-z shows more than 100C) which in turn cause constant fps drop making open world games unplayable (it just gets 87c in 5 minutes in any open world game).
What i have tried is:
The problem came out of nowhere, before this i have never opened my gpu or touched vbios because there was no need)
Gpu: Zotac Rtx 2060 6gb GDDR6
Cpu: i7 4th gen
16gb ram
1tb hdd and 120 ssd (windows in ssd)
Before the problem arrived I have played tons of open world games on this gpu for hours but this problem never occurred before.
What iam considering to do is replace gpu fans,
My fans are 90mm and what i have available to buy in my country is Zotac rtx 2060 AMP fans (90mm).
My gpu is not AMP, therefore will the AMP fans work on my gpu as well? because they look the same, have same size and have same screws points.
Will the fans work on my gpu as well?
- updating drivers (used ddu and then tried both old and new drivers but didn't make a difference)
- Oiling fans
- replacing thermal paste
- used Afterburner and Firestorm to change fans speed (but they were still showing 300 or 400 rpm on 100%)
Cpu: i7 4th gen
16gb ram
