Aug 12, 2020
17
Hello
In seasonic PSU PCie Ports and CPU Ports are in the same group
I want to Know
Which PORTS I have to plug cpu power cables in ??
in the photo there is 5 ports in PSU to PLUG CPU power cables "but" there is only 2 ports are correct for CPU POWER CONNECTOR
I need to Know :
Which 2ports ARE correct to PLUG CPU POWER CONNECTOR ?
PHOTO OF PSU 1000 WATT
https://c1.neweggimages.com/NeweggImage/ProductImageCompressAll1280/17-151-188-V13.jpg
**I Have motherbord has 2x8CPU Power connector - so I need to To know 2 correct ports not one port
It does not really matter which one you plug it into, As long as you have the correct amount of cables for the CPU you are pretty much good to go. As it says CPU/PCI-E on both ports it is basically saying you can plug into either of these.
Hello
I want to Know
I need to Know :
Any of them. Notice that the pins are all the same. The difference between PCIe and CPU is made with the cable. The power supply is all the same.
