vainsy
36
Hey Guys,
I am building a new PC very soon (just waiting for Ampere to release) and am having trouble deciding on my CPU cooler, so I was hoping for a good recommendation.
I will be cooling a 10900K inside a Phanteks P500A. I would prefer to use an AIO as I like the look. It doesn't have to come with RGB fans, but it would be nice, however I would just swap them out down the line if it doesn't.
So far I have looked at using;
  • Coolermaster MasterLiquid ML360R
  • Corsair H115i RGB Platinum
  • Corsair iCUE H150i RGB PRO XT
  • NZXT X63
Thanks in advance for your help!
I'd pick any of the above but only the Coolermaster has 360mm of radiator surface area. Personally I'd go with a larger radiator surface area which can populate the front of the chassis for the sake of uniformity(aesthetics).
Reactions: vMax
As Lutfij has said, any of the above will do a good job, especially the 360mm models. Also take a look at the Arctic Liquid Freezer II 360mm AIO if it is available. Probably cheaper than the above and yet as good if not better...worth a look if available but any of the above will work....
Reactions: Phaaze88
