I upgraded to an EVGA RTX 3070 XC3. Temps are amazing - 60c max.
However, I have experienced random shut downs while gaming (3D Mark not enough to cause shut downs but happened in 2 games so far). The PC shuts off abruptly, PSU needs turned off and on to reboot. (some lights still active, such as USB)
I had the power limit at 113% and core voltage at +100 in MSI Afterburner.
Since disabling these I haven't noticed shut downs. (Still got more testing to do though). Assuming it doesn't shut down with further testing, is this normal? Or a sign of a faulty card? I don't have another mobo or PSU to test these components. But PSU draws 380w max while gaming, even when stressing CPU and GPU with stress tests simultaneously, it draws 450w max.
I had a Palit RTX 3070 before the EVGA (power limit and voltage increased on that as well), but something was wrong with its thermals so I returned it. I never experienced shut downs with the Palit card, however, I have noticed the EVGA card draws 280w max, compared to the 250w max of the Palit card.
Power supply is Seasonic SS-650KM3 X Series. Using 2 separate 8 pin cables to power the card.
Would really appreciate some help with this.
