Hi.
I have just installed ASUS ROG STRIX RTX 2070 O8G GAMING in my new build.
After about half an hour, I noticed a faint noise from the third fan located closest to the power inlet of the gpu.
The noise is as if the fan is rubbing very lightly against something. A sort of a mild whooshing sound.
I noticed that this fan runs at normal speed, but also tends to slow down and do a start-stop kind of thing at times.
Is this normal for a big gpu with 3 fans or should I return it/rma it?
Thank you.
Thank you.
